It is currently Sun Jul 27, 2025 8:13 pm
PostPosted: Wed Jul 16, 2008 9:37 am
I've been buying shell rosettes but they come in standard diameters. Is there an easy way to make a shell rosette of different diameters?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Jul 16, 2008 9:55 am
Cumpiano's book shows his jig. Basically, a disk cut to the correct inside diameter with sandpaper attached and a bolt through the center for the drill press. For the OD a small clamping pivot which is then rotated into the disc.
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Wed Jul 16, 2008 10:46 am
I use the pivot clamp to do the outside of shell, but instead of the disc to do the inner radius, I use a grind stone mounted horizontally in the drill press ....
If you are using 1/16 shell though, you can snap it into a trough anywhere from about 4 inches to almost 6 in diameter without much worry ... BTDT (been there, done that)
PostPosted: Wed Jul 16, 2008 11:41 am
Tony, is it possible to buy the curved pieces (LMI) and shape them? I need a rosette for a hole size 2.75".
Rich Smith
Issaquah, WA
PostPosted: Wed Jul 16, 2008 11:55 am
With abalone is is possible to use standard radius and break them in place to make larger diameter and smaller diameter rosettes. I have done this many times. years ago most abalone rosettes and purflings were made by breaking in place straights of abalone by most of the manufactures as the loss in material was far less.
PostPosted: Wed Jul 16, 2008 12:09 pm
Rich, you can bend them into shape.
Oh, yes you can.
I make my rosette off the guitar on a circular form.
If you use the 1/16" width shell, you can force those
pieces into the diameter you want.
They may go ahead and snap on you, but it's like
Michael describes, with the bonus of having near invisible joints.
PostPosted: Wed Jul 16, 2008 3:13 pm
True.. I snap them in, never done one that small though ....
PostPosted: Wed Jul 16, 2008 4:21 pm
I filed and snapped and fit the individual pieces on my most recent guitar - the diameter's a little smaller than the outer ring, little bigger than the inner, no troubles:
http://www.xs4all.nl/~mvalente/guitarpi ... ette06.jpg
Finding the perfect pieces for an even colour match (I wanted predominant greens with a touch of blue - it's Paua, so it can be all over the map in terms of colour)
PostPosted: Wed Jul 16, 2008 5:00 pm
I use Cumpiano's methods for the inside and outside diameter- they work great.
After I grind the inside diameter I cut a rough but very close outside diameter using a scroll saw with a simple jig that holds the shell at the inside diameter and then pivots with a slightly larger radius than I want for the outside diameter. Then I clean the outside diameter up with Cumpiano's method. I use a spiral bit on the scroll saw.
To miter the edge of the shell I use a disk sander and a jig that holds the shell at the right angle.
I took some pictures the last time I did one. I could post them if there's interest.
PostPosted: Wed Jul 16, 2008 5:43 pm
Mattia, very nice! [:Y:]
Rich Smith
Issaquah, WA
PostPosted: Thu Jul 17, 2008 5:43 pm
Yes, some pictures would be helpful...Thanks,
Ben
- Ben Pak
North Wales, Pa.
PostPosted: Tue Jul 22, 2008 12:02 am
I follow Campianos method. I do a mock up rosette using channels routered into a UHMW chopping board. Once everything fits I use the channels in the mock up to set up the router for cutting the actual top.
PostPosted: Thu Jul 24, 2008 10:31 am
Ben
I start by grinding the inside diameter.
Here’s the jig I use for holding the shell.
This is the only shell cutting operation that I find a scroll saw really good for. Here’s the basic setup.
Here’s the shell locked and loaded ready to go I cut a bit wide and clean-up on the sander.
Halfway through the cut.
Done. With a larger shell it cuts pretty clean all the way through. This one needs more than the usual amount of cleanup
Here’s the setup for cleanup on the outside diameter.
Halfway through.
Done.
I used to go through a lot of saws mitering the ends. Now I use this jig and some sandpaper on an old wet saw. It makes short work of this job.
All done.
Inlaid and all decked out with glitter ready to party!
Users browsing this forum: Bing [Bot] and 23 guests
